查看: 5758|回复: 0
全新立式注塑机125克,上海立式注塑机,百塑立式注塑机 Z...
发表于 2022-2-14 20:04:20 | 显示全部楼层 |阅读模式
型号其他种类其他品牌其他机器型号ZF600螺杆直径Screw diametermm3436**射胶压力Max. injection pressureKg/ cm216201380**理论射胶容积Max. Theoretical injection capacitycm3145166射胶量Shot weight(PS)g132148射出率Shotratecm3/sec148165锁模力Clamping forceton60下模板尺寸Bottom piaten sizemm660×500模板间距(水平×垂直)space between piaten bars(V×H)mm460×310*小模厚MinMouldthicknessmm200 / 300开模行程opening strokemm230**开模行程Max opening strokemm430 / 550顶针推力/行程Ejetor force/stroketon/mm1.75 / 40油泵**压力Pump P. max.MPa14油泵马达功率Oil pump powerKw7.5油箱容量Oil tank capacityL245电热容量Barrel heating powerKW5.6电热控制区Heating numberqty3+N外型尺寸(长×宽×高)Machine size(L×W×H)m1.9×1.2×2.9净重Net weightton2.6
